What is the siren on Wyze Cam Pan v2 and how does it work?
The siren is a really loud speaker.
We’ve improved the volume of the speaker so that it can be used as a siren, which is loud so you can use it to ward off intruders.
👉 Control the Siren feature from the Wyze app manually, or by using Automations.
