Can I use Wyze Cam Pan v2 outdoors?
No, Wyze Cam Pan v2 is for indoor use only.
Wyze Cam Pan v2 is not IP rated, and has not been designed for outdoor use. It will not be covered by our warranty if used outdoors. The lens, speaker, and charging ports are not weatherproof, and the camera should not be mounted or left outdoors for an extended period of time.
Looking for an outdoor camera? Check out Wyze Cam v4 or Wyze Battery Cam Pro on wyze.com!
