Wyze Scale S Setup Guide
Before starting, place your Wyze Scale S on a hard, flat surface and enable BluetoothⓇ on your phone.
To set up your Wyze Scale S:
  2. On the Add menu, tap Device.
  3. Tap Lifestyle > Wyze Scale Series > Wyze Scale S.
    • Your phone will search for your scale, pair with it, and connect to it.
  4. Name your device or choose a pre-selected name, then tap Save.
  5. Add your details (Year of Birth, Height, etc.).
    • You must be between 14 and 100 years old to see Body Composition data.
  6. Tap Next. Your phone or tablet will pair with your scale again.
  7. Step on the scale with bare feet. Your weight will display, then your body fat percentage.
  8. You're all set!
New to Wyze? Before starting, download the Wyze app and enable Bluetooth.
