About Wyze Cam Floodlight
Brighter, smarter, motion-activated security.
Features we love about Wyze Cam Floodlight:
  • Customized Detection of More Than Just Motion. 3 PIR sensors provide 270° of customizable detection. Turn them on and off individually, plus adjust range and sensitivity up to 30 ft.
  • From Detection to Inspection. Know what your detector detected! Wyze Cam Floodlight doesn’t just detect and deter motion, its built-in, award-winning Wyze Cam v3 also identifies motion and records it in 1080p full HD with our can’t-believe-it’s-not-daytime Starlight Sensor color night vision.
  • Dusk-to-Dawn Automation. Wyze Cam Floodlight knows when the sun is down and when it’s up. Just hook it up and never think about your light switch again.
  • Double the Cameras for Double the Coverage. Double your camera coverage and look both ways with an extra port for another Wyze Cam v3.
  • IP65 Weather Resistance. Shrug off dust, rain, and snow with IP65 weather resistance. Wyze Cam Floodlight keeps doing its job in brutal conditions from dust clouds to downpours.
  • 2600 Lumens Floodlight. Two adjustable super bright LED floodlights to cover your entire front yard and scare away intruders.
  • 105 db Security Siren. Use the dedicated siren to warn away intruders (and pesky squirrels) with a loud sound. Control the siren from the Wyze app.
  • Supports Cam Plus. Benefit from state of the art Cam Plus AI features, to detect all sorts of things for longer periods.
