Installing your Wyze Cam Floodlight is as simple as replacing your existing floodlight by connecting it to a junction box. As long as you have a junction box and neutral wiring, and self-installation is legal in your area, this process should take about 30 minutes.
-> You must have an existing junction box and a neutral wire to use Wyze Cam Floodlight.
-> At the electrical panel, shut off power to your junction box before proceeding.
Before you begin installation:
Check your local laws and building codes before doing any performing any electrical work. Your may live in an area that requires a permit and professional installation.
What’s in the box?
- 1x Wyze Cam Floodlight (Assembled)
1x Mounting Accessory Kit
6x Bracket Screws
- 2x #6
- 2x #8
- 2x #10
- 1x Ground Wire Screw
- 1x Floodlight Screw
- 1x Rubber Stopper
- 1x Mounting Bracket
- 2x Wire Nuts
- 1x Hook
6x Bracket Screws
- 1x Quick Start Guide
Required tools:
- Phillips Screwdriver
- Ladder
To install your Wyze Cam Floodlight:
- In the Wyze app, tap the +plus sign then Device > Cameras > Floodlight Camera > Wyze Cam Floodlight.
- Read the High Voltage warning before tapping Got it!
- Select your mounting location, Wall Mount or Ceiling Mount.
- Are you replacing an existing floodlight?
- If yes, tap I'm replacing an existing floodlight.
- At your electrical panel, turn off power to your floodlight. Tap Next.
- Carefully remove your existing floodlight. Tap Next.
- If no, I don't have a floodlight to replace.
- Do you have an existing junction box?
- If yes, tap Next.
- Check that your junction box is at least 10 feet off the ground. Tap Next.
- If no, your wiring is not compatible with Wyze Cam Floodlight. Stop the installation process and contact a licensed electrician for assistance.
- If yes, tap Next.
- Tap Check Your WiFi Signal Strength in the Wyze app.
- If your signal is Out of Range or Poor Connection, contact your ISP for options.
- Tap Continue Setup.
- Tap Start Installation.
Continue below, following along in the Wyze app to wire your floodlight.
- For the device you'd like to install first, tap Wyze Cam Floodlight.
- IMPORTANT: At your electrical panel, shut off power to your floodlight. Tap Next.
- Confirm that you have the required tools and the In the Box items. Tap Next.
- Follow along in the Wyze app, and use the installation video below for reference.
