How do I redeem my Wyze Wits?
Redeem your points from the Rewards widget!
To redeem your Wyze Wits points:
  1. Sign into wyze.com.
  2. Click or tap on the Rewards bubble, then How to spend points.
  3. When you have enough points, pick a reward to redeem.
  4. Go back to click or tap View your rewards to check out.
Be sure to spend your points when you can - Wyze Wits expire after 24 months!
Learn more about Wyze Wits and how to earn points at: Wyze Wits Program.
