Where should I place my Wyze Air Purifier?
Put Wyze Air Purifier in your most-used room.
With one Wyze Air Purifier, the ideal place to put it is in the room where you spend the most time each day. For most people this is the bedroom or living room.
Try to keep your Wyze Air Purifier at least 1 foot away from walls or furniture to avoid blocking the air entrance and exit vents. This allows air to circulate properly and the air purifier to operate more efficiently.
For the most efficient purification, we recommend closing doors and windows in the area you're using the air purifier in. Exception: When using a gas appliance and the air purifier at the same time, keep your windows open for optimal ventilation and safety.
We do not recommend using a humidifier and Wyze Air Purifier in the same room at the same time.
