Unplug Wyze Air Purifier from power before continuing with cleaning. We recommend using a vacuum cleaner to clean the dust attached to the vent and the warehouse wall or wipe these with a soft cloth.
- Does Wyze Air Purifier have pollen insights?
- How heavy is Wyze Air Purifier?
- What does Wyze Air Purifier come with?
- Should I leave the purifier on 24/7?
- Why does the filter arrive wrapped in plastic?
- How do I reset the filter icon?
- Where can I find the Air Quality Index (AQI)?
- Is the Wyze app required to use Wyze Air Purifier?
- How do I clean my Wyze Air Purifier?
- What's the best room size for Wyze Air Purifier?
- See more
