How do I delete a clip from a story?
To delete a clip from a Featured Story:
  1. In the Wyze app, tap on the featured story.
  2. Tap View Full Story.
  3. Tap on the clip you want to delete.
  4. On the clip, tap the three dots menu.
  5. Tap Delete.
  6. To confirm, tap Delete again.
To delete a clip from the Events tab:
  1. In the Wyze app, tap on the Events tab.
  2. Tap on the story in the timeline.
  5. Tap Delete.
What happens when I delete a clip from a story?
The clip is removed from the story's clip list and its thumbnail. The story stays intact with its summary. If you delete every clip in a story, the whole story is removed from your feed.
What happens if I delete a clip from a story?
The clip is removed from the story's clip list and its thumbnail, and the story stays intact with its summary. If you delete every clip in a story, the whole story is removed from your feed.
