The story summary isn't correct. What do I do?
Send feedback to help us improve!
AI-written summaries are usually accurate, but they can misread a scene. Sending feedback helps us fix it.
To let us know that a summary is wrong, give the story a thumbs down 👎. In the pop-up, check the box next to Description is incorrect when submitting your feedback.
To share feedback about a story:
  1. Open the story.
  2. Tap thumbs up 👍 or thumbs down 👎.
    1. If thumbs up:
      1. Remove any videos you don't want to share.
      2. Tap Submit.
    2. If thumbs down,
      1. Select the best option for what didn't work for you.
      2. Remove any videos you don't want to share.
      3. Tap Submit.
