Introducing Wyze Bulb Cam Pan Color
A color bulb. A pan camera. Together.
Features that make Wyze Bulb Cam Pan Color turn heads.
  • Video Surveillance. Smart Lighting. Total Control. A next-generation pan and tilt security camera fused with a full-color smart bulb.
  • 16 Million RGB Colors Set the perfect mood to fit the vibe with 16 million colors for endless lighting creativity.
  • Crisp 2.5K HD Resolution. See every detail with sharp, high-resolution video that captures faces and fine details with exceptional clarity, day or night.
  • Fits your standard E26 socket. No electrician needed. Simply screw in your Wyze Bulb Cam Pan Color and set up in a flash.
  • Brilliant 1,100 lumen LED light.  Illuminate any room with powerful, energy-efficient lighting with up to 1,100 lumens of bright, customizable light, all controlled from the Wyze app.
  • Free AI-Powered Motion Tracking. Automatically follows movement with smart tracking that intelligently detects and distinguishes between people, pets, and vehicles.
  • 360° Pan / 180° Tilt Sees everything. Keep every corner of your space in view. The wide-ranging pan and tilt lets you actively monitor the whole backyard.
  • Group Light Control with Wyze Bulb Color. Seamlessly synchronize lighting effects and color settings with your existing Wyze Bulb Color
  • Dual-Band Wi-Fi + Bluetooth® Setup. Supports 2.4 GHz and 5 GHz networks. Makes initial setup quick and hassle-free – no QR codes required.
  • Expanded Local Storage up to 512 GB. Supports microSD cards up to 512 GB for continuous local recording. (microSD card sold separately.)
Shop Wyze Bulb Cam Pan Color here
