Wyze Bulb Cam Pan Color Tech Specs
Wyze Bulb Cam Device Details
Materials & Colors
  • Model: WYZEC-BCPAN
  • Color: White
  • Finish: Matte
  • Body: Plastic
  • Lens: Glass and Plastic
  • Bulb Base: Metal
  • Certifications: FCC, IC, UL, IP65 (camera part)
  • Telescoping Length: 3 cm
  • Camera Dimensions: 70 mm (H) x 70 mm (W) x 250 mm (D) collapsed
  • Camera Weight: 565 g (1.25 lbs)
Power
  • 120V AC Input
  • Standard E26 Socket
  • Wattage: 24 watts
Video
  • Resolution: 2.5K QHD (2560 x 1440p)
  • Field of View: 115.8° diagonal, 98.5° horizontal, 53.1° vertical
  • Frame Rate: Daytime 20 FPS, Nighttime 15 FPS
  • Pan/Tilt Range: 360° pan x 180° tilt
  • Functionality: Color Night Vision, Digital Zoom 8x
  • Sensor: 1/3"
  • Aperture: F1.6
Audio
  • Microphone: Built-in, digital
  • Siren: 100 dB @ 10 cm
  • 2-Way Audio: Simultaneous 2-way talk
Lighting
  • Brightness: up to 1100 lm
  • Color Temperature: 1800K–6500K adjustable, plus 16M RGB colors
  • Controls: In-App, Motion-Activated Light, Ambient Light, Schedule, Wyze Automations
  • IR Lights: 4x 850nm
  • LED Indicator: Red & Blue
Storage and Alerts
  • Alerts: Push notifications, Motion Warning
  • Cloud Storage: stored in the AWS cloud (Wyze Service subscription required)
  • Local Storage: Supports up to 512 GB microSD cards in exFAT format
Connectivity and Compatibility
  • OS Requirements: Android 10.0+ or iOS 16.0+
  • Wi-Fi: 802.11a/b/g/n/ac/ax, 2.4/5 GHz, Wi-Fi 4/5/6
  • Bluetooth®: BLE
  • Linking: Wyze Bulb Color (Unlimited)
Weather and Temperature
  • Weather Resistance:
    • Camera: IP65 Weatherproof
    • Bulb: UL Damp
  • Operating Temperature: -40°F – 158°F (-40°C – 70°C)
  • Storage Temperature: -4°F – 122°F (-40°C – 80°C)
Warranty
  • 1-year product warranty
