While following the Wyze Battery Cam Setup Guide you'll be prompted to install your camera. Follow along with this video and article to install your Wyze Battery Cam.
What’s in the box?
- 1x Wyze Battery Cam
- 1x Mounting Bracket
- 1x Camera Wall Mount Kit
- 3x Screws
- #6-32 countersunk Philipps-head self tapping screws, 0.984 in long
- 3x Anchors
- 3x Screws
- 1x Charging Cable (2 ft)
- 1 x Mounting Drill Guide
- 1z Outdoor Install Guide
- 1x Quick Start Guide
Note: A 5V/2A power adapter (not included) is required to charge Wyze Battery Cam using an outlet.
- Follow along in the Wyze Battery Cam Setup Guide. Once successfully paired, tap Next.
- Ensure you have the required tools. Tap Next.
- Review the list of installation tips, then tap Next.
- Check your Wi-Fi Strength. Tap Next.
- After verifying that you have a strong connection, tap Next.
- Install the mounting bracket by drilling holes with a ¼-inch drill bit and inserting the anchors. Tap Next.
- For concrete, brick, or similar materials, use the bracket to mark the hole locations.
- Screw the bracket base onto the wall and install the ball-joint onto the base, but do not tighten it completely. Tap Next
- Attach the camera to the mounting bracket by aligning the screw hole on the back of the camera with the bracket screw, then rotate until it locks securely into place. Tap Next.
- Secure the camera by tightening the bracket locking ring completely.
- Adjust the device to the desired angle, then tighten the locking knob to lock the ball-joint in place. Tap Next.
- Once installation is complete, follow the in-app instructions to complete setup.
- You're all set! Tap Done and enjoy your Wyze device.
