Yes, but it is turned off by default.
Wyze Window Bird Cam does have a status light, but it is disabled after setup so the light doesn’t reflect on the glass.
To turn on the status light:
In the Wyze app, tap on your Wyze Window Bird Cam.
Tap Settings > Advanced Settings.
Tap the toggle next to Status Light.
Note: If the status light is turned on, it may reflect on the glass and may cause false or missed detections.
