Yes, Wyze Window Bird Cam is compatible with Wyze Web View.
Which Wyze Cams are compatible with Wyze Web View?
Currently, Wyze Web View allows you to view the Live stream and Event videos on the following devices:
- Wyze Indoor Cam Pan
- Wyze Bulb Cam
- Wyze Window Cam
- Wyze Cam Floodlight Pro
- Wyze Cam Floodlight v1
- Wyze Cam Floodlight v2
- Wyze Cam OG
- Wyze Cam OG Telephoto 3x
- Wyze Cam Pan v1
- Wyze Cam Pan v2
- Wyze Cam Pan v3
- Wyze Cam Pan v4
- Wyze Duo Cam Pan
- Wyze Solar Cam Pan/2K
- Wyze Cam v2
- Wyze Cam v3
- Wyze Cam v3 Pro
- Wyze Cam v4
- Wyze Duo Cam Doorbell
- Wyze Video Doorbell v1
- Wyze Video Doorbell v2
- Wyze Battery Cam Pro
Wyze Web View also allows you to view the Events only on the following devices:
- Wyze Cam Outdoor v1
- Wyze Cam Outdoor v2
- Wyze Video Doorbell Pro
Wyze Web View is not available on Wyze Cam v1.
Additional Notes:
- Free users without a subscription can select one camera to livestream on Wyze Web View per month.
- Wyze Web View is not available in the Wyze app.
