To clean Wyze Window Bird Cam’s bird feeder:
Remove and empty the feeder tray and nectar pod. Do not remove the window mount.
Wash the feeder parts with mild soap and water, and rinse thoroughly.
Let the feeder parts dry completely before reinstalling.
Keep the camera, cable, and power adapter and cable dry. Wipe the camera with a dry, soft cloth as needed.
