No, Wyze Window Bird Cam does not work with a solar panel.
Wyze Window Bird Cam is an indoor-only camera, mounted to the inside of the glass. It is not compatible with Wyze Solar Panel or any of our others, which work with specific indoor/outdoor cameras and are mounted outside.
For a bird watching solution that works with a solar panel, check out Wyze Bird Feeder.
