Bird Highlights Troubleshooting
Problem
You cannot find a recap, expect daily/video highlights, see missing cards, or notice an incorrect species/image/metric.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that Wyze Window Bird Cam’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Verify when Bird Watch was enabled.
    • The past month’s Bird Highlights are generated on the first of the following month.
  4. Check whether Wyze Window Bird Cam is a shared device.
    • Bird Highlights are only visible to the account owner, not shared users.
  5. For a wrong image/species, compare the recap card with the source event.
    • Note: A species that was edited after it was generated will not reflect in the recap.
  6. For count differences, refer to Bird Numbers Troubleshooting.
