Bird Watch gives inaccurate bird detections or events
Problem
Bird Watch names the wrong species, it gives you the same bird different names, or tags other motion as birds.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that Wyze Window Bird Cam’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Ensure that there is nothing impairing the camera’s lens.
    • Remove any plastic film or cover from the lens.
    • Gently wipe the lens with a soft cloth to remove any dust or debris.
    • Check that both the inside and outside of the window are clean and transparent.
      • Note: We do not recommend mounting Wyze Window Bird Cam to a window that has a screen on it.
    • If there is a third-party cover on the device, please remove it.
  4. Verify that there are no additional light sources next to or pointing toward the camera lens that may cause interference.
    • If the camera is in the direct path of the sun, it is possible that a lens flare appears in the image. We recommend adjusting the position of the camera so that the view is not in the direct path of the sunlight, but this is an expected phenomenon in standard cameras.
  5. Minimize background motion/triggers, which is the main source of false bird events.
    1. Adjust the position of the feeder and camera so the feeder fills the frame and busy background motion is minimized.
    2. Create a Detection Zone.
      1. Navigate to the camera’s settings > Detection Settings.
      2. Enable a Detection Zone to exclude areas with busy motion.
    3. Adjust the Event Recording settings.
      1. Navigate to the camera’s settings > Event Recording.
      2. Enable Motion.
      3. Select Smart Detection Events, then tap Customize Recordings.
      4. Ensure only Bird options are selected.
  6. If the false triggers are caused by indoor lighting during dusk/dawn, try adjusting the Daytime-Only Recording schedule to exclude the unwanted time periods.
    2. Enable Motion.
    3. Toggle on Daytime-Only Recording.
    4. Set a schedule and test during the set schedule.
Note: Accuracy drops for shadowed, backlit, partially visible, or very distant birds. Dawn/dusk shots identify less reliably.
