Wyze Cam Pan v3 Setup Troubleshooting
Problem
Wyze Cam Pan v3 does not complete setup or gets stuck at the “Select your Network” step.
Troubleshooting
  1. Confirm your Wyze app is up to date.
    • In your Wyze app, go to the Account tab > tap About.
    • Your current app version will be listed beneath the Wyze logo.
    • Compare your app version to the latest app version listed here on our Release Notes & Firmware page.
    • If you find that your Wyze app is out of date, head over to your mobile device’s app store, and update the Wyze app.
  2. Check that the camera’s status light is flashing red and that there's a “ready to connect” voice prompt after pressing the setup button.
    • The status light for Wyze Cam Pan v3 is at the front of the camera.
    • If the camera status light shows as solid red, please follow the steps listed in My camera’s status light shows as solid red.
    • If the camera does not show a status light, please follow the steps listed in My Wyze Cam Pan v3 does not power on.
    • If it doesn't say “ready to connect,” please follow the steps listed in There are no voice prompts during setup.
  3. Make sure that your phone/tablet is connected to the same 2.4 GHz Wi-Fi network that you are entering at the Select your network step and you are entering your SSID (Wi-Fi name) correctly.
    • Wyze Cam pan v3 is not compatible with 5 GHz Wi-Fi networks.
    • The SSID is case-sensitive and there should be no space before or after the SSID.
    • The SSID should automatically populate if you are connected to Wi-Fi. If it does not auto-populate, it can indicate the phone/tablet that is being used for setup is not connected to Wi-Fi.
  4. Check that you are entering the Wi-Fi password correctly.
    • You can tap on the eye icon to view the password you’re entering.
  5. Check that your device has location permissions enabled for the Wyze app.
    • If using iOS, ensure local network permissions are turned on in the phone/tablet’s settings.
  6. Make sure the camera and phone/tablet are close to the router for setup (within 6-10 feet).
  7. Forget your Wi-Fi network on your phone/tablet and rejoin the network. Then try setting up the camera again.
  8. Power cycle the camera by unplugging it from its power source for 5 seconds and then plugging it back in.
  9. Factory reset the camera and then set it up as new.
    1. Remove any microSD card inserted in the camera.
    2. With the camera plugged into power, rotate the lens of the camera so it is facing up and single-press SETUP for 10 seconds until the status light on the front of the camera lens turns solid red.
      • Single-pressing the SETUP button will not reset your Wyze Cam Pan v3. You must press and hold the SETUP button for 10-20 seconds, until the status light turns red, to reset the device.
    3. Once the status light starts flashing red, set up the camera as new.
  10. Reboot your router.
What happens when you factory reset your Wyze Cam Pan v3:
  • The device settings and previous Wi-Fi/setup state are cleared.
  • The current firmware version remains intact.
  • The camera must be set up as a new device before it can be used again.
