How do I stack Wyze Cam OG cameras together?
Before you stack your cameras, make sure you have a Wyze Cam OG Stack Kit
To stack two Wyze Cam OG cameras:
  1. Remove the standard base from the bottom of the camera you plan to have on top.
  2. Attach the stack mount to the bottom of the camera you plan to have on top.
  3. Remove the stack cover on the top of the camera you’d like to use as the base camera.
  4. Insert the stack mount into the stack shoe of the base camera.
    • The arrow on the mount should be pointing toward the center of the camera.
  5. You should hear/feel a click once the stack mount is fully inserted into the stack shoe.
  • Live Support Hours:
