How do I manage automatic firmware updates?
Wyze Cam OG supports the Automatic Update feature, which allows your device to update its firmware silently, without interruption. Automatic Update is enabled by default, and can be managed from your camera's settings.
To turn off automatic updates:
  1. In the Wyze app, tap on your Wyze device.
  2. Tap the Settings gear, then Device Info > Firmware Version.
  3. Tap Automatic Update.
  4. Tap to toggle this setting off.
To update your Wyze device:
  1. In the Wyze app, tap Account > Firmware Update.
  2. Tap Update next to your device.
    • Don't see Update? You're already up to date!
    • Update multiple Wyze devices at once by tapping Update[#] at the top of the screen.
