What is Night Vision on my Wyze Cam OG?
Night Vision allows you to see better in the dark!
The Night Vision feature gives your Wyze Cam OG the ability to see in dim or dark light.
To enable Night Vision on Wyze Cam OG:
  1. Navigate to your Wyze Cam OG's settings in the Wyze app.
  2. Tap Advanced Settings.
  3. Under Night Vision Mode, select your desired setting.
    • On - Your camera will stay in Night Vision mode with a black-and-white image until you manually disable it.
    • Auto - Your camera will automatically switch to Night Vision based on the surrounding light levels.
      • When enabled, you can choose if you want the camera to switch to Night Vision when the surrounding light is Dusk (low light) or Dark (extremely low light).
