Does Wyze Cam OG Telephoto 3x use an optical or digital zoom?
Wyze Cam OG Telephoto 3x uses both types of zoom!
Wyze Cam OG Telephoto 3x has a set 3x optical zoom that can’t be changed. However, you can zoom in further using the 8x digital zoom in the Wyze app.
💡 Optical zoom uses the lens to physically magnify the image, while digital zoom enlarges the image electronically by cropping and enlarging the image.
To digitally zoom your Telephoto 3x:
  1. In the Wyze app, navigate to your Wyze Cam OG's Live stream.
  2. Double-tap or pinch to zoom in and out.
