What is Motion Warning on Wyze Cam OG?
Wyze Cam OG keeps unwanted visitors away with a voice message or tone!
With this feature enabled, when motion or a person is detected, your camera will say, "Hi, you are currently being recorded" or emit a Wyze Tone and repeat every 30 seconds while the detection continues.
To enable Motion Warning on Wyze Cam OG:
  1. In the Wyze app, tap on your Wyze Cam OG.
  2. Tap the gear icon in the upper right-hand corner to get to the settings, then tap Detection Settings.
  3. Tap Motion Warning then select Wyze Tone for a simple sound alert or You are being recorded for the "Hi, you are currently being recorded" voice message.
