Wyze Wireless Gaming Headset Setup Guide
To set up Bluetooth® pairing:
  1. Press the power button on the headset for 5 seconds.
    • The status light will turn solid red.
  2. Press the Multi-Function Button for 5 seconds to enter pairing mode.
    • The status light will flash blue.
  3. On the device you're pairing with, turn on Bluetooth. Find Wyze Wireless Gaming Headset and connect.
  4. Once pairing is successful, the headset will beep.
    • The status light will turn solid blue.
To set up your Wyze Gaming Headset dongle:
  1. Plug the dongle into the USB port of the device you want to connect to.
    • The headset will beep when the dongle is inserted.
  2. The status light will turn solid white when connected.
  3. To set up your headset with a new replacement dongle, press the power button 5 times to enter USB dongle pairing mode.
To switch between Bluetooth and dongle mode:
Press the Multi-Function Button twice. The status light will turn blue for Bluetooth mode, and turn white in dongle mode.
Note: Dongle mode will not activate if the dongle is not plugged in.
Still need help?
