Wyze Wireless Gaming Headset Specs
Wyze Wireless Gaming Headset Tech Specs
Headset Weight and Materials
  • Weight: 10.8 oz
  • Headband material: Plastic, protein leather and aluminum
  • Ear cup cover material: Protein leather
  • Ear cushion material: Memory foam
Bluetooth Specification
  • Bluetooth range: Up to 49 ft with no obstacles
  • Bluetooth codec: SBC, AAC
  • Bluetooth version: 5.2
  • Multiple device connection: Supports two device connections at the same time
Speaker
  • Driver dimensions: 50mm
  • Magnet material: NdFeB
  • Diaphragm: composite
  • Frequency response: 20 Hz ~ 20 KHz
  • Sensitivity: 112.5 dB ± 3 dB/mW
  • Total Harmonic Distortion: < 0.5% @ 1 KHz
  • Impedance: 32 Ω
Battery
  • Charging method: USB Type-C
  • Battery life: Up to 20 hours
  • Charging time: 3 hours
  • 10-Minute quick charge: up to 2 hours of battery life
  • Charging temperature: 32℉ - 113℉
  • Battery type: Lithium-ion rechargeable battery
  • Battery capacity: 600 mAh, 3.7 V
Microphones
  • Built-in microphone:
    • Sensitivity: -40 dB ± 3 dB (0 dB = 1 V/pa, 1 kHz)
    • Directivity: Omnidirectional
    • SNR: > 58 dB
    • Frequency response: 50 Hz - 10 kHz
    • Size: 4 mm
  • Detachable boom mic:
    • Sensitivity: -38 dB ± 3 dB (0 dB = 1 V/pa, 1 kHz)
    • Directivity: Unidirectional
    • SNR: > 58 dB
    • Size: 6 mm
Control input
  • Power/pairing/switch LE and BT
  • Play/Pause
  • Answer/Hang up/Reject call
  • Mute/Unmute
  • Volume dial
Temperature
  • Operating environment: 32°F - 104°F, ≤ 85% RH
  • Storage and transporting environment: -4°F - 140°F, ≤ 95% RH
