My Wyze Lamp Socket is not turning on/off automatically.
Problem
Wyze Lamp Socket is not turning on/off when set to Auto.
Troubleshooting
  2. Confirm the firmware for your Wyze Cam and Wyze Lamp Socket are both up to date.
    2. If there is an update available for these devices, please move forward with updating them.
  3. Verify that there are no Automations set up that could be causing interference.
    1. Navigate to the Home tab of the Wyze app, tap Automations.
    2. Note: We recommend deleting any Automations and then adding them back one by one while testing.
  4. Make sure the settings for Wyze Lamp Socket are set correctly.
    1. In the Wyze app, navigate to your Wyze Cam’s settings > Accessories > Wyze Lamp Socket.
    2. Under Lamp Socket Control, tap Auto.
    3. Under Turn on when, select Sunset to sunrise.
    4. Set the Timer to the desired length.
      • The Timer will keep your lamp socket turned on for a custom length of time before automatically turning off.
  5. Ensure that Wyze Lamp Socket has a good signal strength.
    1. You can check this in the Wyze app by going to the attached camera’s settings > Device Info > Signal Strength.
    2. If it has less than 3 bars, try moving the lamp socket and Wyze Cam closer to your router.
  6. Reboot your router.
  7. Power cycle Wyze Lamp Socket.
    1. Change the light switch (or breaker) for the circuit that the lamp socket is attached to into the off position.
    2. Wait 5 full seconds.
    3. Change the switch (or breaker) back to the on position.
    4. Note: This will power cycle both Wyze Lamp Socket and the attached Wyze Cam.
  8. Factory reset the attached Wyze Cam.
    1. If there is a microSD card inserted in the camera, remove it before proceeding.
    2. With the camera plugged into power, press and hold the setup button on the bottom of the camera for 10 seconds.
    3. Wait at least 30 seconds for the unit to initialize.
      • This process may take up to 5 minutes. It's rare, but it's possible.
    4. The LED status light on the camera will change to flashing red once the reset is complete.
    5. Walk through setting up the camera and lamp socket like new in the Wyze app.
