My Wyze Lamp Sockets are not linking.
Problem
Wyze Lamp Socket is unable to link with other Wyze Lamp Sockets.
Troubleshooting
  2. Confirm the firmware for your Wyze Cam v3 and Wyze Lamp Socket are both up to date.
    2. If there is an update available for these devices, please move forward with updating them.
  3. Verify that the lamp sockets you are trying to link are not already grouped.
    • Note: Only 5 Wyze Lamp Sockets can be linked together at a time.
  4. Ensure all Wyze Lamp Sockets are turned on within 30 seconds of each other.
  5. Move the impacted Wyze Lamp Sockets closer together if possible.
  6. Power cycle Wyze Lamp Socket.
    1. Change the light switch (or breaker) for the circuit that the lamp socket is attached to into the off position.
    2. Wait 5 full seconds.
    3. Change the switch (or breaker) back to the on position.
    4. Note: This will power cycle both Wyze Lamp Socket and the attached Wyze Cam v3.
