How do I turn on Color Night Vision?
Turn off Night Vision (no, really).
By default, Wyze Cam Floodlight Pro will automatically turn on when motion is detected. From the floodlight’s Advanced Settings, turn off Night Vision Mode. The camera will switch to color night vision.
Only a little light is needed for a clear image and a street or night light outside works. If you need more light, you can manually turn on the floodlight in the Wyze app for better illumination.
