Wyze Cam Floodlight Pro is compatible with Cam Plus, Cam Protect, and Wyze Web View. You can learn more about Wyze Services here.
- Why do I have to enable Location Permissions to use Wyze Cam Floodlight Pro?
- What is the Ambient Light feature on my Wyze Cam Floodlight Pro?
- What is the range of motion detection?
- What is BluetoothⓇ Low Energy (BLE) used for?
- What services are compatible with Wyze Cam Floodlight Pro?
- How to limit false alerts, detections, or light triggers.
- What is Vision AI?
- Does Wyze Cam Floodlight Pro need a neutral wire?
- Can I change the brightness or color of the floodlight?
- Can I use the floodlight without a camera?
- See more
