Can I change the brightness or color of the floodlight?
While the brightness is customizable, the color is not.
Wyze Cam Floodlight Pro is a 5000K White LED. While you can’t change the color of the light, you can change the brightness.
To change the brightness:
  1. In the Wyze app, tap on your Wyze Cam Floodlight Pro.
  2. Tap on the settings gear > Floodlight Settings.
  3. Under Brightness Level, adjust the slider bar to your desired brightness.
    • Note: This will change the brightness for all 3 light panels. You cannot adjust them individually.
For more automated brightness control, check out our Ambient Light feature.
