How to limit false alerts, detections, or light triggers.
Adjust the detection sensitivity or create a detection zone.
With Vision AI on Wyze Cam Floodlight Pro, you’re already there! Vision AI limits motion detection to Person or Vehicle detection. Learn more here.
For additional customization, you can adjust the detection sensitivity or create a detection zone all from the Wyze app!
To adjust the sensitivity:
  1. Navigate to the floodlight’s settings > Detection Settings.
  2. Under Motion Detection Sensitivity, adjust the slider bar to your desired sensitivity.
    • We generally recommend about 40 or lower.
To create a Detection Zone:
  2. Tap Detection Zone and toggle it on.
  3. On the grid, tap the squares where you would like your floodlight to detect motion.
  4. Tap Save.
Note: Only motion detected within the Detection Zone will generate motion Event recordings or motion light triggers.
