What is the Ambient Light feature on my Wyze Cam Floodlight Pro?
When enabled, Wyze Cam Floodlight Pro provides constant, low-level ambient lighting until motion is detected and automatically switches to increased brightness.
To enable Ambient Light:
  1. In the Wyze app, tap on your Wyze Cam Floodlight Pro.
  2. Tap on the Settings gear > Floodlight Settings.
  3. Under Ambient Light Settings, tap Ambient Light.
  4. Toggle on Ambient Light.
  5. Under Brightness Level, adjust the slider bar to your desired brightness.
  6. Under Ambient Light Schedule, tap Schedule then set your desired start and end times.
Additional Notes:
  • Ambient Light is disabled by default.
  • Ambient Light is set as 10% brightness by default.
  • Ambient Light Schedule is set as sunset to sunrise by default.
