The chart below shows how Wyze Cordless Vacuum compares to Wyze Cordless Vacuum S.
| Wyze Cordless Vacuum | Wyze Cordless Vacuum S | |
| Battery Life | Up to 50 Minutes | Up to 40 Minutes |
| Charge Time | 4-5 Hours | 4-6 Hours |
| Max Suction Power | 24000 Pa | 20000 Pa |
| Additional Insert Included | Yes | No |
| Wall Mount Base Included | Yes | No |
| 2-in-1 Brush Included | Yes | No |
Note: The battery pack and charger are not interchangeable across devices. Although the other accessories such as the crevice tool, HEPA filter, dust cup, and more are cross-compatible, we recommend using the same accessories that came with your vacuum.
