How do I charge Wyze Cordless Vacuum?
Connect the charging cable, then plug into an outlet.
There's no extra charging dock or station needed for Wyze Cordless Vacuum. Simply attach the included power cable to the vacuum's Main Unit, and attach the other end into a power outlet.
What is the Wall Mount for? Is it a charger?
The included Wall Mount is for storing your cordless vacuum and its attachments. It is not a charger, though it can be placed near an outlet for easy charging with the included charging cable.
