Wyze Web View crashed while viewing the live stream.
Problem
You've logged into Wyze Web View, but it crashes while viewing the live stream.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
  2. Check that the camera’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Check that the camera is connected and that the live stream can be viewed in the Wyze app.
    • If the camera's live stream does not connect, refer to the specific camera's connectivity troubleshooting steps in our Help Center.
  4. Verify that the device being used (phone, tablet, or computer) is able to connect to the Internet.
    1. Open a browser on the device to check that the device can successfully access the Internet.
  5. Try using a different browser.
    • Wyze Web View works best on Google Chrome, but alternative browsers include Microsoft Edge and Safari.
    • Note: Wyze Web View is not supported on Firefox browsers.
  6. Check if the issue is still present while using an incognito browser window.
  7. If possible, connect to a different Wi-Fi network and try to view Wyze Web View.
  8. If using a phone, try connecting to mobile data, then try to view Wyze Web View.
  9. If possible, try using another device to view Wyze Web View.
  10. Clear the browser’s cache.
    • For Google Chrome: Select the three dots in the upper-right corner > Settings > Privacy and Security > Delete Browsing Data > select the time range > check Browsing history, Cookies and site data, Cached images and files > Delete data.
    • For Microsoft Edge: Select Settings > Privacy, Search, and Services > Clear Browsing Data > select the desired options > Clear now.
    • For Safari: Select Preferences > Privacy > Manage Website Data > Remove All.
  11. Confirm that there are no security or network restrictions on the device and that WebRTC (Web Real-Time Communication) and view.wyze.com are not blocked.
    • This includes any firewalls, VPNs, or any other network restrictions on the phone/tablet/desktop.
    • Note: Some firewalls or network configurations may block WebRTC traffic due to security policies, which can prevent Wyze Web View from functioning properly.
