There's no sound when viewing Wyze Web View.
Problem
You don't hear any sound while viewing Wyze Web View.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
  2. Check that the camera’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Confirm that you are hearing sound when viewing the live stream of your camera in the Wyze app.
    1. Toggle the live stream’s sound off, then back on.
  4. Ensure the device you are using to access Wyze Web View has the correct audio output selected, and the volume is turned up.
  5. Try using a different browser.
    • Wyze Web View works best on Google Chrome, but alternative browsers include Microsoft Edge and Safari.
    • Note: Wyze Web View is not supported on Firefox browsers.
  6. Check if the issue is still present while using an incognito browser window.
  7. If possible, connect to a different Wi-Fi network and try to view Wyze Web View.
  8. If using a phone, try connecting to mobile data, then try to view Wyze Web View.
  9. If possible, try using another device to view Wyze Web View.
  10. Clear the browser’s cache.
    • For Google Chrome: Select the three dots in the upper-right corner > Settings > Privacy and Security > Delete Browsing Data > select the time range > check Browsing history, Cookies and site data, Cached images and files > Delete data.
    • For Microsoft Edge: Select Settings > Privacy, Search, and Services > Clear Browsing Data > select the desired options > Clear now.
    • For Safari: Select Preferences > Privacy > Manage Website Data > Remove All.
