Problem
You've logged into Wyze Web View, but the camera's live stream fails to connect.
Troubleshooting
Verify that the camera is compatible with Wyze Web View.
- You can check this here: Which Wyze Cams are compatible with Wyze Web View?
- Confirm that the Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store, and update the Wyze app.
- Check that the camera’s firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the camera, please move forward with updating it.
- Confirm that there is an active subscription and the camera is assigned to it.
- In the Wyze app, go to Account > Services > tap the three dots next to the subscription > Manage Subscription.
- Note: For Cam Plus subscriptions, tap Manage Camera to ensure the correct camera(s) are assigned to the subscription.
- Check that the camera is connected and that the live stream can be viewed in the Wyze app.
- If the camera's live stream does not connect, refer to the specific camera's connectivity troubleshooting steps in our Help Center.
- Verify that the device being used (phone, tablet, or computer) is able to connect to the Internet.
- Open a browser on the device to check that the device can successfully access the Internet.
- Try using a different browser.
- Wyze Web View works best on Google Chrome, but alternative browsers include Microsoft Edge and Safari.
- Note: Wyze Web View is not supported on Firefox browsers.
- Check if the issue is still present while using an incognito browser window.
- If possible, connect to a different Wi-Fi network and try to view Wyze Web View.
- If using a phone, try connecting to mobile data, then try to view Wyze Web View.
- If possible, try using another device to view Wyze Web View.
- Clear the browser’s cache.
- For Google Chrome: Select the three dots in the upper-right corner > Settings > Privacy and Security > Delete Browsing Data > select the time range > check Browsing history, Cookies and site data, Cached images and files > Delete data.
- For Microsoft Edge: Select Settings > Privacy, Search, and Services > Clear Browsing Data > select the desired options > Clear now.
- For Safari: Select Preferences > Privacy > Manage Website Data > Remove All.
- Confirm that there are no security or network restrictions on the device and that WebRTC (Web Real-Time Communication) and view.wyze.com are not blocked.
- This includes any firewalls, VPNs, or any other network restrictions on the phone/tablet/desktop.
- Note: Some firewalls or network configurations may block WebRTC traffic due to security policies, which can prevent Wyze Web View from functioning properly.
- Power cycle the camera.
- Disconnect the camera from power for 10 seconds before reconnecting it.
- If possible, restart the camera.
- In the Wyze app, navigate to the camera’s settings > Restart Camera > Restart.
- If possible, reset the services for the camera.
- In the Wyze app, navigate to the camera’s settings > Reset Services > Reset.
- Factory reset the camera and set it up like new.
- Wait about 30 minutes, then try viewing the cameras using Wyze Web View again.
