How do I use Sun Match on Wyze Light Strip?
Sun Match automatically adjusts your light’s color temperature to mimic natural sunlight, letting you bring the outdoors indoors!
To enable Sun Match on your Wyze device, simply navigate to your bulb's settings in the Wyze app and toggle on Sun Match. You can also create an Automation to enable or disable Sun Match.
To create an automation for Sun Match:
  2. On the Add menu, tap Automation.
  3. Select Shortcut, Schedule, Device & Service Trigger, or Location Trigger, depending on the type of automations you'd like to create.
  4. Make sure to select Turn Sun Match On or Turn Sun Match Off for the action on your specific Wyze Bulb device.
Note: The Sun Match feature is only available for Wyze Bulb White v1/v2, Wyze Bulb Color, Wyze Bulb Color BR30, Wyze Light Strip, and Wyze Light Strip Pro.
