Yes, both versions have 3M adhesive backing.
- How do I use Sun Match on Wyze Light Strip?
- Can I change the light segments to different colors?
- Do the light strips have adhesive backing?
- How long are the light strips?
- Can I use Wyze Light Strip outdoors?
- Can I use the trimmed portion of a light strip?
- Does Wyze Light Strip work with 220V?
- Does Wyze Light Strip have energy monitoring?
- Does Wyze Light Strip work outside of the US?
- Do I need a hub to control Wyze Light Strip?
- See more
