Yes, Wyze Light Strip Pro can show up to 14 different colors at once.
Note: This feature is only available on the Wyze Light Strip Pro.
To change the individual light segments:
- In the Wyze app, tap on your Wyze Light Strip Pro.
- Tap Design.
- Press and hold your Wyze Light Strip Pro’s device icon in the top left corner.
- Select which segments of the light strip you would like to be the first color.
- Press X.
- Tap and drag along the color wheel to select the color you would like the selected segment to be. The previously selected segments of the light strip should automatically change to the selected color.
- To adjust the color of additional segments for your Wyze Light Strip Pro, repeat the steps above.
