Yes, Wyze Video Doorbell v2 is compatible with Alexa and Google Home!
Use your smart speakers to view the Live stream of people at the door on your Echo Show and Google Home devices. You can also use your Echo device* as a doorbell chime!
What doorbell functions are available on my smart speaker?
Alexa Echo |
Google Home |
| Voice Notification when someone is at your door |
Yes (Setup in Alexa App)** |
Yes |
| Auto-open live stream when the doorbell is pressed |
No* |
| Show Live Stream |
Yes (Through Voice command or Tap) |
| Two-way talk | Yes | No* |
To use Wyze Video Doorbell v2 with your smart speaker:
Enable the Wyze Skill on the Alexa app.
- Or, connect Wyze to your Google Home app.
- Add your Wyze Video Doorbell v2 to your Alexa/Google Home app.
- In the Wyze app, make sure Person Detection is enabled under Smart Detection.
- You must have a subscription to Cam Plus or Cam Protect to use AI detection.
- On the Alexa or Google Home app, enable Person Detection notifications.
* Google Home doesn’t support 3rd-party doorbell ring notifications.
** You must turn on notifications and set up a routine via the Alexa app.
*** AI Motion detection requires a subscription to Cam Plus or Cam Protect.
