Yes, Wyze Video Doorbell v2 is compatible with Alexa and Google Home!
Use your smart speakers to view the Live stream of people at the door on your Echo Show and Google Home devices. You can also use your Echo device* as a doorbell chime!
What functions are available on my smart speaker?
Alexa Echo |
Google Home |
Voice-triggered Live stream | Yes | Yes |
Voice prompt when the doorbell is ringing | Yes, via Alexa app** | No* |
Auto-open live stream when the doorbell is pressed | Yes, via Alexa app** | No |
Two-way talk | Yes | No |
* Google Home doesn’t support 3rd-party doorbell ring notifications.
** You must turn on notifications and set up a routine via the Alexa app.
