Navigating the Monitoring Tab
You can quickly view and manage your live streams from the Monitoring tab in the Wyze app. With a subscription to Cam Unlimited or Cam Unlimited Pro, you can also arm/disarm your cameras.
To edit the cameras shown in multi-view:
  1. In the Wyze app, navigate to the Monitoring tab.
  2. Tap the right arrow >, then View Multi-Cam.
  3. Under the multi-view of the live streams, tap the camera and pencil icon.
  4. Drag and drop and sort the cameras which you want on the specific page.
  5. Tap the back arrow <. Your changes will change automatically.
Please note: You can only add up to 16 cameras over 4 pages. If you have more cameras, they will be shown under Available Cameras. They will not be added to multi-view.
To remove cameras from multi-view:
Tap and drag the camera from the page.
You can also quickly look through events and locate particular AI events using the timeline feature. Underneath the multi-view, you will see a timeline that contains the Event videos for your cameras. Simply tap on an Event to view it.
Please note that this timeline will only show Events associated with the cameras being shown in multi-view. Recordings for any other cameras can be found in the main Events tab of the Wyze app.
The Monitoring tab is also where you can access your Cam Unlimited settings.
To access Cam Unlimited settings:
  1. Tap the drop-down arrow in the upper right-hand corner.
  2. Tap Settings.
  3. From here you can adjust the camera modes and notifications.
    • You can learn more about modes here.
