How do I use Video Search to find Events?
You have the Video Search feature, but now what? Here's a quick how-to on how to search your Event videos with Video Search.
⭐️  Video Search Checklist: ⭐️
  • Event Recording enabled? ✅
  • Cam Unlimited subscriber? ✅
  • Enrolled in Video Search? ✅
When you've ticked all of those boxes, you’re ready to try Video Search!
To use Video Search:
  1. Open the Wyze app and go to the Events tab.
  2. Tap on the Video Search icon at the top of the screen.
  3. Follow along with the tutorial, if prompted.
  4. In the search bar, enter a search phrase.
    1. If there are any matches, your results will display below.
    2. If there are no matches, try simplifying your search.
  5. After reviewing your results, consider giving us some feedback by tapping the 👍 or 👎 .
  6. That’s it! That is how you use Video Search.
