What is the NBD (NoBigDeal) Filter?
The NBD (NoBigDeal) Filter is a new Cam Unlimited Pro feature!
With a subscription to Cam Unlimited Pro, you can avoid repetitive notifications being sent to you while still continuing to record videos to the Events tab in the Wyze app.
To enable the NBD filter:
  1. In the Wyze app, tap on the Account tab.
  2. Tap Wyze Intelligence > Descriptive Alert
  3. Tap the camera you want to adjust.
  4. Tap NBD (NoBigDeal) Filter.
Note: You must manually update your settings on each camera if you want to have the NBD Filter turned on. This feature is not enabled by default.
You can find more details about the NBD Filter here.
