What is 60-day cloud storage?
Extended 60-day cloud storage is a Cam Unlimited Pro feature!
With a subscription to Cam Unlimited Pro, you can extend the standard 14-day cloud storage limit to up to 60 days. 😮  You must have a subscription to Cam Unlimited Pro to get 60 days of cloud storage.
To enable 60-day cloud storage:
  1. In the Wyze app, tap on the Account tab.
  2. Tap Video Cloud Storage.
  3. Tap the camera(s) you want to increase the storage limit on.
  4. Tap 60 days storage, then Save*.
Note: You must manually update your settings on each camera you want to have 60-day cloud storage on. This feature is not enabled by default.
Additional Notes:
  • * You can only change this setting once per day. If you update from 14 to 60 days of cloud storage, you cannot switch back to 14 days the same day.
  • 60-day cloud storage cannot be applied to find events in the past. If you update the setting today, you will not have 60 days of past events recorded.
