What is AI Video Search?
AI Video Search lets you quickly find recorded events using an AI-powered text search. Enter a search phrase like "kid in a green coat" or "Brown UPS truck" to find specific event recordings without scrolling through your entire event history.
AI Video Search FAQs
How do I get AI Video Search?
Only Cam Unlimited Pro subscribers get the AI Video Search feature. Once subscribed, you'll find the feature at the top of your Events tab.
How do I use AI Video Search to find Events?
  1. On the Events tab in the Wyze app, tap on the AI Video Search icon.
  2. Follow along with the tutorial, if prompted.
  3. In the search bar, enter a search phrase like "dog in backyard."
  4. If there are any matches, your results will display.
  5. No matches? Try simplifying your search. That's it!
Can I get this feature with Cam Plus, Cam Unlimited, or Wyze Home Monitoring?
No, AI Video Search is only available Cam Unlimited Pro subscribers.
How can I submit feedback about AI Video Search?
You can submit feedback directly to our AI team from the Video Search results, the Events tab, or at my.wyze.com.
What do I do if I don't have any search results?
If you enter a search phrase but don't get any results, consider:
  • Checking if you have Event Recording enabled on your Wyze Cams.
  • Using a simpler phrase, like "dog in yard" instead of "white doggo on grass."
  • Searching for something more general, like "yard."
  • Only Events recorded after upgrading to Cam Unlimited Pro will be searchable.
