How do I enable Descriptive Alert?
While purchasing Cam Unlimited Pro, you'll be prompted in the Wyze app to give consent to the Descriptive Alert feature on my.wyze.com. If you do not give consent, you'll be prompted in the Wyze app to give consent. You must give consent in order to use Descriptive Alert.
To enable Descriptive Alert on your cameras:
  1. In the Wyze app, tap on the Account tab.
  2. Tap Wyze Intelligence > Descriptive Alert > Push Notifications.
  3. Tap to enable Descriptive Alert on your cameras.
    • Note: Some Wyze Cams do not support this feature, and may be grayed out.
If Descriptive Alert doesn't display in your Account settings in the Wyze app, then you have not given consent while purchasing or in the Wyze app.
